Hi guys and gals,
Looking for opinions on my already completed installed and running build.
1968 318 in a 68 Barracuda notch with 904 and 8 3/4 323 suregrip stock converter...about 1700 stall??
Here's the build
318 bored .040 over. KB forged 1.81 CH pistons floating pins.
Block decked and pistons .003 in the hole with .040 head gasket.
360 rods on a forged crank.
Heads are Hughes PN# HUG 20301A Indy/RHS LA/X, 62 CC closed chambers with 1.920 and 1.620 valves off the shelf with no port work and stock rockers off the original heads.
Eddy air gap manifold with a Holley 4150 650 cfm carb #3 power valve.
Cam is a Comp XE268H. Closest I could get is 105.5 intake centerline on the degree wheel with a cloyes double roller with a chain tensioner.
Pertronix Flame Thrower Distributor.
Ceramic coated headers with H pipe.
Issues:
Low vacuum...idle 16"Hg...in gear idle 10-11" HG. Doesn't like ported vacuum. Compensated with a crane adjustable can with stop, on manifold vacuum allowing 6* advance at idle. Base timing is 18* BTDC with a base and VA total at idle of 24* BTDC. (Idles much better now). Mechanical is all it at 3000 with stops set at 35* total base and mechanical.
It actually gets 15.95 MPG freeway on 90 ethanol free real gasoline if I don't use the loud pedal. No detonation.
It likes to run hot in traffic... extreme I've seen is 210*. Haven't steam cleaned the engine compartment yet with a lifted the radiator cap.
What do you think my compression ratio and HP would be with this setup?
Would I do better with a lower/ higher base timing and changing the VA can stop to keep me at 24* idle timing and keeping the total mechanical and base at 35-36* all in with the stops.
It's a strong motor but it just feels like I'm leaving something on the bench...maybe it's that 360 sitting over there that I decided against in favor of the matching numbers 318.
Here's the build
Issues:
