69dodgedart360
Well, after a compression test, 11 years and about 50,000 HARD miles, I am taking out my 360 and building a 408 stroker. I was looking at this kit and if anyone has any experience, I had a few questions.
https://m.summitracing.com/parts/sca-1-98113bi
To anyone that has experience building a 360 based stroker, I have read that sometimes you have to clearance the bottom of the bores. Is this true with Scat I-beam rods? Is there a particular rod or stroker kit I can purchase that does not require any block clearancing?
Is there any other things I should mention to the machine shop when I send them the block?
Thanks in advance.
Thanks in advance.
