My 63 Valiant
jacjazz
New Member
Memphis
My Valiant Slant 6 engine was recently rebuilt, rebuilt carb, time belt reset,everything possible.
It will start but only runs for 10-15 minutes...stops running then won't start for two days..my mechanic is baffle..suggest I talk to mopar expertise ...any suggestion. please help
jacjazz
Any other symptoms?
How does it stop running?
Just idling, or is there some driving during those 15 minutes?
Loss of power, more loss of power, then dies? Or just flat dies?
Back to basics. One possibility is trash in the fuel, clogging the filter. After choking the engine out, it may settle out and allow it to run later. Fine rust in the gas tank can do this.
If the car has been retrofitted with electronic ignition, a faulty module can also cause problems as it heats up.
What ignition? What carb?
Follow Charlie's advice and report back.
Narrowing it down to no spark or no gas would help a lot.
