According to my parts manual the correct pn is 3870059, but I’ve had no luck even finding a picture of a manifold with that number, let alone the actual manifold. I want to get this right so I guess I’ll keep looking for it.
That certainly throws a new wrinkle into things. Thanks for sharing that. It looks like I have some additional research to do before I install a right hand exhaust manifold.Interesting.
When I upgraded my 318 with a 4bbl, although my Scamp already had a dual exhaust, it was small diameter and quite old (installed in the early ‘90’s), so I replaced it with a 2.5” exhaust with the 71+ 340/360 exhaust manifolds. The 318 manifolds I had removed looked exactly like the pair you recent found Tanker (passenger side one had the ribs on it).
Those look like the same ones I have on my 75 318s. I have a very original 75 duster and a 75 swinger. Starting in 75 they are supposed to look like 360 manifolds like that. 74 and 75 had different manifolds on a 318I finally managed to track down what I believe to be the correct factory exhaust manifolds for a 75 on eBay. They'll need some cleaning up prior to use, but that's not a problem. At some point in the future I may very well put headers back on the car, but for now I'll have a shop fabricate the pipes to connect these to the dual exhausts the car has. That being said, I'll never discard the factory manifolds again the way I did when I put the headers on at 18. I like the idea of being able to return to a stock configuration if I want to.
Looks good to meI think the 75 and up manifolds are less restrictive because you can see the ports are bigger. I even thought they were 360 manifolds at first but the 75 duster has the same ones. I think the later ones are better but more overlooked because of the prejudice against later 74 and up stuff
3 to 4 speed swap is going to be very easy. Should be the same bellhousing and everything bolts in the same place.
Only difference is going to be the slip yoke. The 3 speed uses the smaller 904 yoke and the 4 speed uses the bigger 727 yoke.
The 3 and 4 speed are the same length so your driveshaft will work by swapping the slip yolk.
This is assuming you have an A body 4 speed
Thanks Princess. It’s been nearly forty years since I bought that four speed and it’s tucked away where I haven’t even seen it in about half that time. I’ll see if I can get one of my nephews to send me a picture of it so it can be identified. I seem to recall that it came out of a Duster that the guy had put an automatic in, but I don’t really trust my memory from that far back.3 to 4 speed swap is going to be very easy. Should be the same bellhousing and everything bolts in the same place.
That’s a 1971 Plymouth Satellite wagon with a slant six. And yes, I’m lucky to still have the car after all these years.Was reading theu your thread again. Pretty cool that your parents didnt junk it or sell it on you. I hear too many horror stories of people going into the armed forces, and for some reason their folks sell their stuff. I honestly dont understand why people do that. BTW what brand of wagon is that in the backround in your first pic? Is it a chevelle wagon?
