my cam
70wayfarer
new zealand
contacted Hughes Engines regarding cam hydraulic roller recommendation for my 360/410 stroker S475 turbo. this is street strip. gave them all the appropriate info and this is what they came back to me with. what you guys think....
506/510 lift, duration @ .050" 219/221, installed cl 111*, lobe seperation 115*
Are we supposed to read your mind through the internet what your combo is with the car?
fair enough...
360/410 stroker
eagle crank and rods
icon premium forged pitons -34 stepped dish
cr 8.3:1
edelbrock rpm heads mild porting
efi 90mm throttle body
link g4+ extreme ecu
85# injectors
24x12x4 air to air bar/plate intercooler
aem 30-3300 water/meth kit
727
3800 ptc converter
cope full manual reverse pattern vb
3.55 rear gears
28" tire
leaf springs
3200lb car weight
also want to know if 2x walbro gl 392 pumps will do the job for fuel delivery.
cheers
Yeah. Them pumps are pretty badass. I think two will be more than enough.
That said, I am no turbo expert, but to me that cam is a little mild.
i don't mind that it seems mild for now. will look at a more aggressive cam later on. suits what i want to do right now. will still give me 10's on the 1/4.
Oh it'll work GOOD. It's probably right on the mark considering it is a stroker and does not have to turn a lot of RPM.
