Well this is the segment where you learn that life happens!
![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
ops:
Since I started the Demon I have found myself in a different position. I am now getting divorced. No I am not selling the car. But! I am however going to be changing what I am doing with the car.
The list of things to come and hopefully when you will see these changes.
Art Morrison full tube chassis Next month.
Aeromotive belt drive pump, Regulator, and fuel log.
408 Stroker steel crank, 11:1, Eddy heads with a twist and a cam that will be talked about after the motor is running!
Weld Alumna Star wheels
MSD 6AL2 ignition
Autometer gauges
9" rear by Pyle Bros. Differentials
Strange struts, brakes, and rearend
ATI Powerglide, and converter
And you probably guessed it.
Painless Wiring
All fabrication will be done by BJS racing.
More to come hopefully in the next month.
