My duster is officially a v8 car FINALLY!
dustyaman
conway ar
Finally my 360 is in the duster and is running! No transmission yet but did a bell housing modification to be able to get the the starter to bolt up to the transmission. Used a truck manual bell housing with the flywheel that came with the engine. Engine specs are: 360, .030 over, low compression, big valve j heads, comp cam xe268he cam, rpm air gap intake, brawler 650 carb mechanical secondary,
Doug's ceramic coated headers. It's come a long way from being a slant six car. I've always wanted a small block in my car. Alot of wiring modifications involved since the wiring was made to fit the slant.
kylewiseman74 on TikTok
I also wanted to thank everyone on this forum also. There was so much research i did searching the forums. There are so many good, smart individuals on this forum. Thank you to everyone.
Sounds very potent.Nothing like the sound of open headers. I like it.
Great job, very healthy sounding! I would love to see more pics, the straight and clean body in B1 powder blue really does it for me with that one...
I would definitely recommend it. I used a cast crank, eagle sir rods, hypereutectic pistons. All cheap parts. I think I spent about $1000 at the time for the rotating assembly.
Maybe down the road I will build another engine while I drive this one around and enjoy it.
Looks awesome.
Looks great.
