my turbo slant
I like this video better than the other. Cameras don't really convey speed or the pull very well, but don't worry, I know what's going on.
Also your oil psi gauge is crooked. Cool shirt. :happy1:
Well that is outstanding. Sounds like it's fairly smooth throughout the throttle range. Really cool.
If that fedex truck would have pulled out of your way you might have got air borne.
Blow thru? What rear gears you running? Is your 3 speed a 3.09 first? Do you have a build thread?
Wow, sounds fantastic. Nice Job! Makes me want to ditch the triple Weber idea and just do a turbo.
yea the video doesnt do it justice. if you watch closely you can see the tach rock when im on or off the gas. you are more then welcome to stop by, ill take you out for a blast.
oil gauge has been like that since i put it in. doesnt bother me.
i was going to pass him but there is a speed trap just on the other side of that bridge. goes from 45 to 25 with almost no warning.
not sure of the gearing in the tranny. it could be. 3.21 sure grip out back with a 26" tire.
here is my build http://slantsix.org/forum/viewtopic.php?t=54407
Very cool, sounds great and looks like It moves out good too! My 66 used to be a 170 with a 3-speed column shift, really takes me back watching you shift that thing, now I row gears with a pistol grip :burnout:
