Mystery fuel pump
pishta
I know I'm right....
Tustin, CA
Got this and don't really know what I have. Maybe a 650HP NA fuel pump? Anyone recognize the design? Weldon brand. When I apply 12v it will almost jump off the table.
The quality suggests military. Might not even be for fuel, or at least, gas. Chemical, hydraulic, ??
It's most likely an alcohol pump used for aircraft de-icing systems. It does not look like the type of pump Weldon makes for automotive use.
cool, I got a de-icing pump! but I live in so. Cal....... :-( Maybe Ill make my parts washer/solvent tank now.
Got reply from weldon. It's a pump....mainly suited for aircraft: 45GPH (min) at 60psi. @13.5V. Relief set at 175psi. It could work for efi at rail regulated 48psi.
