dodgemahal
I'm restoring a 1973 4 door Dart Custom. There is a 2-wire harness with a connector at the end that's under the carpet and just to the right and adjacent to the transmission hump. What does this connect to?
Brilliant! That makes perfect sense. No console here, with a 4 door. Thanks!Usually pink and white wires indicate lighting. that is probably console pigtail.
Basically, for this year, power for the warning system comes from ignition1 (key run position only) routed to the seatbelt relay and one side of the buzzer/light. The relay primary is triggered by a ground from either the parking brake switch(manual) or the NSS (automatics). The normally closed relay completes a ground path, when the parking brake is off or not in park/neutral, to the retractor switches wired in parallel (closed with the retractor fully retracted) with the right seat weight switch open without weight to remove the right retractor switch from the circuit when the seat is not occupied. Key on, parking brake off or in gear for autos, driver’s retractor not extended equals warning lights and buzzer. Right seat occupied includes the passenger retractor.Okay, now I feel like an idiot. I looked at my bench seat, which has been out of the car for 2 years, and to my surprise it does have a weight triggered switch. How do all these components work together? I assume the dash light stays on until the seatbelts are buckled. Does the passenger weight cause the right retractor to open the circuit to the dash lamp? I'm fuzzy on this.
That is a fantastic write-up. I'm going to print it and frame it and hang it on the wall. How do you know all of this? You must be nerdier than me. I got it now, thanks to you. I'm doing a factory OE resto and I want everything to work as it did when it left the factory.Basically, for this year, power for the warning system comes from ignition1 (key run position only) routed to the seatbelt relay and one side of the buzzer/light. The relay primary is triggered by a ground from either the parking brake switch(manual) or the NSS (automatics). The normally closed relay completes a ground path, when the parking brake is off or not in park/neutral, to the retractor switches wired in parallel (closed with the retractor fully retracted) with the right seat weight switch open without weight to remove the right retractor switch from the circuit when the seat is not occupied. Key on, parking brake off or in gear for autos, driver’s retractor not extended equals warning lights and buzzer. Right seat occupied includes the passenger retractor.
