bigtommy
old school power
does any one know the name of the part in the picture with a circle around it? is goes from the wheel to the pitman arm.
the bar is the tie rod adjustment sleeve, the little threaded arm with a ball joint is a tie rod...
Just sayin
to remove the tie rod from the center link and lower ball joint, usually, i loosen the nut to the end of the tie rods threads, and hit the nut with a dead blow hammer...
okay, go to your parts store and ask for tie rods for your car, see what they give you.....i betcha 100 bucks you aint gettin tie rod "adjustment sleeves" with that same part number...so therefore, the tie rod adjustment sleeve, is not a tie rod...
i took a hammer to it and it still didnt come outIf you are currently removing these parts from the car, then the pitman arm puller would be the tool to remove that arm that comes off your steering box and connects to the centerlink. (all the parts pictured are the parts that connect from that centerlink to your hubs which the wheels brakes are attached to.
They have a tool called a ball joint spreader, or separator.
If you don't care about the parts that are coming off, then remove the cotter pins, take the nuts off and smack the end of the threaded part sharply and it's out.
They are called tie rod ends, so I really don't know what else to say.
The parts store would call the inner or outer tie rod ends.
I'm not trying to start anything, it's just that he asked for the correct names of the parts.
tie rod ends...
http://www.google.com/#sclient=psy-....,cf.osb&fp=b029594140d8629d&biw=1280&bih=702
tie rod adjusting sleeves...
http://www.google.com/#hl=en&sugexp....,cf.osb&fp=b029594140d8629d&biw=1280&bih=702
We are both right due to old school an current terminology.
Lots of searches come up with both terms.
Lets just help this guy if we can ok?
haha okay okay!!! fineeeeee!! LOL
bigtommy, if ur not gonna re-use your tie rod ends, then just hit it harder, theyll pop out, or use a pickle pork
Ball joint spreader, joint separator,,,,,,,I KNOW, pickle pork?
Sorry man, you asked for it.
