Name that body part. Hahaha
Cudaman77
Member
Grove City, Pa
Can anybody out there tell me what the name of this panel is? I’ve got some wrought on it and the cowl to gender brace. I’ve tried looking for the replacement piece but can not find it any where and don’t know what name search under.
Welcome to FABO.
You'll get better response if you put query in appropriate area.
The rot I see is all what I would consider the cowl. Is it just what is visible or is it bad inside? Not sure what brace you mean...
Lot's of guys on here parting cars. Put it up as a WANTED for either full cowl pieces or sections you want donor metal cut out. If just fixing the holes, I'd probably just use any sheet metal and cut/bend to fit.
Still repairable. My '65, which I'll post over the weekend had some rot in around the same area. Car just came back with a custom paint job. OEM sheet metal still hanging.
