Name This Connector
jonn6464
1970 Duster
Weatherford, TX
Hey FABO, can someone please tell me what this connector is called, so I can see about ordering some? It's from a tail light.s Inside the black plastic is a male spade connector.
Anyone know if these come as a pigtail with open ends (like just bare wire, to be connected to the original wiring)?
Thanks
Let us know whatr you find.
These types of connectors were used by Chrysler in several locations including the distributor magnetic pickup.
So far I have not seen an exact match or the name that get us one that will be sure to fit until you buy it and try it.
One name is polarized connectors.
Distributor pickup on top
Kindof works but not good. Also the wires look to be at least one size smaller.
Here's the same type of connector on my '85 Jeep Grand?Wagoneer
While doing my emergency Lean Burn delete, I found those connectors w pigtails on the shelf at an O’Rielleys auto parts store. Cant remember the product line, but maybe they were with the towing/trailer stuff?
I was up against this trying to find the mopar electronic distributor plug (replacement pigtail)
Stumbled across this make shift plug that I cut down from a trailer wiring cord. Surprising it fits the connections well. Does not look factory, but it was good engough to use testing my mopar HEI upgrade.
This pigtail came with a mopar brain box wire up kit, $$$
Trailer Plug that I cut down.
About 5 bucks a piece for the trailer plugs new.
So yeah, still looking for the factory plugs if anyone knows where to find them ar a reasonable price.
Thanx
