whitepunkonnitro
Bracket Master II; Camshaft; Hyd.Flat Tappet; RPM 2000-5500; Adv.Dur. 292 Int./Exh.; Valve Lift .480 Int./Exh.; Lobe Angle 109 Deg.;
Removed from a barely run shortblock. Shows zero wear on any lobes. Give it a bath, a fresh set of lifters, and you're good to go.
Asking $50 plus the ride. PM me if interested. Thanks FABO!
