sprinter6591
I bought a '68 Cuda and need help from anyone with experience in installing a 6.1. I'm on a budget, so I'm having to spend sparingly.
I'm going to use the stock exhaust manifolds, instead of headers, due to cost. I need to know if the steering column, with power steering, will clear the stock exhaust manifolds. Also, is there any way the a/c compressor will go in with the stock exhaust and aftermarket motor mounts?
I've heard jeep or truck engines have the a/c mounted on top. Is that true? If it is, would that be a better way to go?
If I can afford it, I'm going to put a carburetor on it. Which intake manifold has the lowest profile to get the most hood clearance?
Any suggestions for this project would be greatly appreciated. Thanks in advance. It's MOPAR or no car.
