Need a speedometer pinion
Tony Fields
That's How I Roll
Legendary Member
Columbus, Indiana 47201
I need a speedometer pinion for a 1972 727 tranny.
Let me know $$$ if you have one
Looks like this:
This is what it calls for for a 3.55 with 30" tires. I have a 26 tooth now.
Thanks,
Tony
I think a 31 tooth gear is going to still read a bit fast. With a 3.55 rear and normal size tires the gear should be a 34 or 35 tooth type. How much bigger are the tires you plan to use over the stock size?
grrr first I'm right, then I'm wrong, then right again. I dont know how to place a pic in a pm. Look here at the 34 tooth and a 31 tooth LOL
