need a stock pic of a 70 a body 440 727 kickdown linkage...
flathead31coupe
indianapolis indiana
I have a bunch of pieces of different kick down linkages, looking for a pic or diagram of a stock 70 440 kick down linkage all the proper pieces...thanks
never made one. The 440 is taller than the factory A's 383 so if you are looking , it would be off a B-C-E. I think the only piece that would be different would be the vertical bar.
thanks I was told that the 440 were three piece...found this 383/440 4-Barrel Carb 3-Piece Kickdown Linkage A-Body. Fits 1967-75 A-Body with Original 3-Piece Style Linkage. Kit Includes Linkage with Upper & Lower Bellcranks, Transmission Throttle Lever, Return Spring & Hardware.
The kickdown linkage, I used with the thermoquad seemed to work ok...but with the Holley it will only go half throttle,because the kick down is all the way back at the trans...
just slap a lokar or bouchilon cable on there and call it good
