Need a trunk lock
plymouth67
It be a lot cooler if you did...
illinios
My buddy needs a trunk lock for 70-74 cuda. All the ones they list are not the correct one so I thought i would see if anybody here had one.
It is a 73 but when you look up the part number it gives you a cylinder wich is not even close to what it takes.
I took this one off a '74 Cuda.....should be the same. I don't have a key for it though. $25.00 plus the ride.
Thanks, Mark
Thanks, Mark
I assume you have the key? I will let him know and see what he wants to do.
