Need Advice on '65 Barracuda Brakes...
Brakes for your Classic Mopar
  1. eekvonzipper
    eekvonzipper Jack Of All Trades and Master of Many!
    16
    17
    Apr 18, 2020
    Old Mines, Missouri
    Local Time:
    3:12 AM
    So, it pulls hard to the right... Started the Bleed Process. No Fluid to Rear, at All.
    Okay, I'm thinking Collapsed Line from the Frame to the Rear End. Moving On...
    No Brakes on Drivers Front, Opened it up and it's Soaked with Fluid.
    No Problem, Two New Wheel Cylinders for the Front, (Napa here I come)
    at this point I'd be happy with just the front working til the next round...
    So, thinking everything is in order, I start to bleed the new front cyl's...
    Now, No Fluid to the right side that was previously working but the drivers side is now fine?
    Pedal does Not go down when you bleed the rear or the right side.
    So did I collapse lines or do I have a Prop Valve problem?
    Can the P Valve really stop the fluid from getting to the two different places at once?
    Where do I start from this point?
  2. Krooser
    Krooser Reform School Graduate
    2,180
    1738
    Jul 19, 2015
    Central Wisconsin
    Local Time:
    3:12 AM
    Replace your brake hoses... They look good on the outside but not inside
    • Thanks! Thanks! x 1
    • eekvonzipper
      16
      17
      Apr 18, 2020
      Old Mines, Missouri
      Local Time:
      3:12 AM
      They Look pretty bad on the outside too actually...
      Just Ordered them from O'Reilly Auto for $13 dollars each...
      Will they fix it it? I'm not sure.
    • circlepilot
      circlepilot FABO Gold Member FABO Gold Member
      661
      404
      Nov 15, 2014
      El Dorado, Arkansas
      Local Time:
      3:12 AM
      What Krooser said! Had the same problem on my 65 after it had sat for 26 years. Change them all, front and rear.
      Norm
      • Agree Agree x 1
      • eekvonzipper
        16
        17
        Apr 18, 2020
        Old Mines, Missouri
        Local Time:
        3:12 AM
        Any Experience with Problem Equalizer Valves or No?
      • pishta
        pishta I know I'm right....
        16,856
        6523
        Oct 13, 2004
        Tustin, CA
        Local Time:
        1:12 AM
        65 didnt come with any prop valve, just a distribution block (4 port manifold) off the single pot MC. 1 in/2 fronts out and a rear out. Brake lines can delaminate and swell inside. Buddy took his bosses Ferrari F40 out for its quarterly spin around the block and he came back dragging the left front wheel all the way down the parking lot. Brake line just swelled shut under pressure! We cut it in half and it was a solid rod of what used to be rubber. "Hey NAPA, you got a front left brake hose for an '87 Ferrari F40? ......no? OK. Try Autozone? sure...thanks..."
        • Agree Agree x 1
        • eekvonzipper
          16
          17
          Apr 18, 2020
          Old Mines, Missouri
          Local Time:
          3:12 AM
          I cut open the right side line, then she sprayed like a Rhino!
        • Toqwik
          Toqwik Well-Known Member
          65
          25
          Nov 1, 2019
          Florida
          Local Time:
          4:12 AM
          When you replace these lines, remove your old line and press the pedal down once. It should go down to the floor. This will tell you if your issue is further upstream. Good luck with your project.
          • eekvonzipper
            16
            17
            Apr 18, 2020
            Old Mines, Missouri
            Local Time:
            3:12 AM
            All done! Thank You Guy's! So, I had Two Collapsed Lines Front Right and Rear, Replaced All Three. Replaced All the Hard Lines and All four Wheel Cylinders. Distribution Block was a Non-Issue and the Master Cyl is good. I Did All the Shoes and Springs while I was in there.
            I probably spent around $200 all told, but we're good now and It Was Worth It! Thanx Again!!
