1970boy
what would it take to put my 70 dart in the mid 12 range with mileage above 15 per gallon
Many many times probably im trying to weigh out every option i can before i setup my build if youve got a problem with someone asking for help then thats you... no need to be a jerk to someone just asking for advice.. Ever think about that?Dude... How many times are you going to ask this?
use a stock bottom end 440 with closed chamber heads 509/292 cam 3.23 gears and if you want to go low 11s high 10s just add big shot nos don't forget to use good piston ringswhat would it take to put my 70 dart in the mid 12 range with mileage above 15 per gallon
this ^who builds a 12 second car and cares about mileage
Then i have 1000 mopar guys up my *** about not having a mopar engine lolAn LS motor.
