[WANTED] Need Carb
Ron Vess
New Member
Vinton, Va.
Rating - 0%
0   0   0
I have a 1965 Barracuda 273 CI 4 Barrel engine. Currently has a Edelbrock and can't get the shift pattern right. Would like to buy an original carb. Good condition would be great but will have rebuilt if needed.
Or help to get mine working?
Thanks
I moved this to a wanted ad for you. Perhaps you should start a thread in the apropriate section asking for some help on what you have already. Fuel and Air Systems
Welcome to FABO
Carb should not make a difference on the shift pattern, you need to make the proper adjustment on the trans.
Probably just needs the Mopar throttle adapter....
