moparkid340
ok so im taking my 318 and swapping it out for a mildly built 340 with a 512 lift cam can i still use the stock 318 904 converter and get by on the street with out any issieus?
But the big issue is that cam. What's the duration on the cam? Lift means very little. Duration is what determines the rpm range in which it performs and how it idles. If it's the Mopar perf 512 lift cam in my opinion that's way too much cam for a stock converter. You might be able to use it but most likely it'll be a major dog out of the hole and not idle well in gear. You probably need at least a 2800 stall for a cam that big and a loose converter will let it idle in gear much better.
