NEED Demon Gas Cap
greenmachine
New Member
Rating - 0%
0   0   0
I'm looking for a gas cap that fits a 71 Demon. I bought one that came off a 70 Duster and it fit loose. I also bought an aftermarket Stant and it was even more loose than the one off the Duster. The one I need would have to have the prongs real close to the cap. Any help would be appreciated. email me at sonichsen@sbcglobal.net or call me at 708-243-3174. Thanks
They should all be identical. I've found that if the rubber seal on the cap is old, the cap will fit very loosely on the car. Installing a new (or thicker) seal will tighten it up. I once just installed two seals to make a chrome cap fit my 75 Dart Sport better.
Hope this helps.
if your car is a 71 is it also a california emmision car? if it is it will have a seperate vent tube in the trunk. it will be coded n 95 on the fender tag. if this is the case then you have a different fillerneck. i know as i went through this also. 1971 had a 1 year only filler neck with a different cap. finding an original cap to fit it will be very hard. your only alternitive will be to replace the filler neck with a non emmisons cap. a 1970 or newer or 1972 or newer will work as long as it is from an abodie. swinger, scamp, dart sport, duster are all the same. good luck..........
