Need Door Jam Switches
swerven11
Detroit, MI
I have a 73 dart swinger and i am looking for the door jam switches for the driver and passenger side. The problem that i have is they are 1/2" threads not 3/8" does any no where i can get a working pair? driver side has 2 prongs and passenger side has one plug in end. Thanks
check other chrysler corp cars at a local yard, I'm pretty sure that they are the same up through the 80's (metal center pin instead of the plastic nib ones). My dad's company had dodge vans as fleet vehicles and the back doors used the metal center pin ones til about '91. I've got one off of an old harness, but I'll have to see if it's any good.
Not sure but I think one pin works the light, the other the key-in-lock buzzer. 86 the buzzer or T into the line you can connect to a single pin switch. This is assuming you can't find a proper two-pin switch anywhere.
I'm pretty sure Advance and Autozone both carry them or can special order them for you, try their on line catalogues.
I bought new ones for my 74 Duster from Napa last year.
They probably still carry them.
