Need help finding a pully
I have a matched set $50 + ship
Ok so I have the pullys lined up and when I put the ps pump on the pully did not line up so how would I know what pully to use.
what pump do you have? saginaw or federal?
sure you have the proper pulleys on the water pump and crank and proper alt brackets?
pictures of your set up would help..
are they all matched? no a/c pulleys and brackets or all a/c brackets and pulleys??
get pictures when ya get home. we will be able to help ya out better. a wp change shouldn't have screwed things up unless its the wrong pump.
Heres some pics are the 318/360 pumps and brackets the same
just shim out the power steering pump. i wouldnt change the PS pump pulley over that. i agree with Joe. that top pulley looks funky anyway. are you trying to use an AC top pulley with a non air bottom? the power steering rides the outside crank groove and the alt , water pump ride the inside crank groove
these are the parts you need to make things line up properly..
not 100% sure whats up with your steering pump mount. never saw one that looks liek that one..
use the measurements below to make sure you gatrher the proper pulleys..
Holly S^%# thats alot of money for pullys were can I buy a full matched set.
Not sure what pullys these are it a mix.
Were can I get
Water pump
Crank
PS
just use the pics i posed for the measurements.. those pulleys will pop up in the classified section from time to time..
looks like some also came on dakotas so look at junk yards also..
looks like you have early model pulleys not 70s pulleys...if you cant find what you need,i have a cleaned primered painted set for a 75 318..they are a matched set..my last set tho..60 plus shipping from antioch cal.pm me for p[ics if interested...j
most 70s era trucks were smallblocks and didnt have a/c but did have power steering. thats where i got mine (from my ol 73 D100 actually)
I posted a pic of mine & I also have the matching alt bracket st up $75 for both pulleys & the alt bracket set up with bolts.
