FrozenCaveman
I managed to get the oil pressure light to come on with the sending wire grounded. I either found a bad spot to ground it, or all the prodding I did on the junction box at the firewall got the connection going. It still doesn't light up on the pressure switch itself. So either my connection is bad there, or the switch is bad. What kind of reading does the pressure switch give off such that I could test with my multimeter? It's just providing variable resistance to ground, right? So, similar to the gas sending unit, I should be able to get some sort of resistance reading if I have one probe on it and the other to ground? But I assume the engine has to be running?
