Need help identifying a Mopar Purple cam
vntned
Gibsonville NC
Anybody know what the specs are on this cam?! It has a "891492" stamped on it.
Yeah, I don't have the cam in hand, otherwise I'd have put a caliper on it before asking.
Measure the lobe lift, which is the highest dimension less the lowest, on the two frontmost lobes. Then a quick check in the catalog will get you to the closest one, if it is a purple. usually.
AJ , with all the math you always use in your posts, I can't believe you didn't tell him to multiply the lobe lift by 1.5 !
If those are not your hands than whomever hands you are using, ask them >>
