LovetheA's
I figured this is the best group of people to help with this problem. It appears that after replacing my dash bezel a leak has developed in the gas gauge on my 67 Cuda. I noticed that a small portion(about quarter size) of the gauge down near the base of the needle is stained darker apparently from fuel. Before pulling the cluster apart what is the issue? Faulty gauge, loose connection? Any ideas? Once the gauge is stained from fuel will I have to replace the gauge? I'm thinking fuel will permanently ruin the silk screening.
Carl
Carl
