I have a 67 barracuda vin#BH23E72336365 Chrysler Heritage sent me a copy of the build card but the quality is poor at best. There are many columns with a dark black rectangle on them. The printing on the columns is not legible. They listed some options for it but left a couple blank like TRIM:= H5X, accessory group:=0, accessory group:=7. Is paint code 881 bright blue metallic the same as B5 blue? I have no fender tag and am trying to document that this is a Formula S. What does Galen do? I have seen people brag about there car being documented by Galen. I would like proper documentation and a fendertag, is he the way to go? Thanks in advance FABO
Accessory Group 36 with a 7 is a Formula S.
Look at the left and right sides of your build card, there are numbers going up starting from 9.
On the bottom there are numbers going from 1 to 80.
So, in your Accessory Group #36 (the numbers on the bottom) the punch hole in that colume should be aligned with the 7s on the left and right.
So, Formula S is equal to 367, which translates to F7 on the Fender Tag.
Trim H5X, I almost don't believe it!! That is a a black split bench seat, same as mine. Is yours a 4 speed?
881 is bright blue metallic.
E is 273 CID/235 HP 4 BBL V8.
If you send me your build card I can decode the entire thing for you.
FYI: Chrysler used the build card to make the fender tag and the buildsheet, and they are supposed to be more accurate.
