need info on notch in LD340 intake carb plenum
Oldmanmopar
Going left turning right
Danielsville Pa. 18038
I need the size and the location of the notch in a LD340 intake can someone get me the measurements Thanks Oldmanmopars Son Steve, HTA machine
https://www.mopardiy.com/building-mopar-engines-for-performance-intake-manifolds/
From that page
Originally, the old LD-340 aluminum Edelbrock produced the best horsepower and torque numbers. Cutting the divider down between the two plenums delivered more power. You should leave a 3/8-inch-high wall at the bottom, and leave points on either end. This mod is effective for any dual-plane.
