Greg A-M
Active Member
Currently 'Pinkie', my 74 Duster, has a cludged together throttle bracket that theoretically lets the car move under it's own power. Picture of that is the first picture.
Specifics of the car: '74 Duster with 225 with 1bbl Holey 1920 and an A-904 for the trans.
I'm looking for info on and eventually the correct throttle bracket with it's linkage and everything it needs to attach the kick-down arm.
Second picture shows the current state of things. At the right you'll see the dangling kick down from the trans and at the left you'll see a dip-stick tube with nothing to bolt on to.
I've looked around and found a few places talking about brackets and linkages (FABO mostly) and pulled one of the following pictures from the site.
Is this the set up I'm looking for? Pic three is from another user's ad and the last picture is of what looks to be a complete set up.
What do I need? *And* if you've got what I need what do you want for it or where can I get it?
