transman
Company test mule. Had a 904 (with GM BOLT Pattern). Can't say for sure, but I don't recall issues with the converter hubs. Mind you, as the test mule, there is the possibility that the impeller for the converter might have been made in the CNC shop????It's a known problem with higher HP motors and the thinner hub thickness of the 904. 727 does not have the issue.
