Need pict of your 63-65 slant6 power steering setup
trapster
Central Florida
I am converting from manual to power and I am missing the pulley(s) that are needed to drive the pump.
I think it is just a pulley attached to the harmonic balancer but I am not sure.
I have a 63 dart, but I don't think there is a difference til after 65 in what I am looking for.
Also I do not have air conditioning, that's a project for another day.
Thanks is advance.
David
Yup, what you're after is a drive pulley sheave that bolts to the front of the crank pulley (harmonic damper). They are all the same, from '60 clear on up through the end of separate bolt-on pulleys for p/s and a/c in about 1981 or so. Should be available without too much cost or delay if you put up a parts-wanted ad here and on the parts-wanted section of the slant-6 board.
is it just one pulley or does the PS belt also drive the water pump ?
The P/S sheave drives only the P/S pump. Uses a short belt. Take note there is also a bolt-on pulley sheave for the rear of the crank pulley (towards the engine), which is for A/C. Not the same sheave; you need the one meant for the front.
