need rad cap
Snake
Mopar Nut
Belleville Canada
Never bought one but what rad cap do i need.My rad is a 3 row,360 mildly built,50/50 mixture,14 pound cap or what.thanks in advance.Buy the way it get hot here and cold here.
Go to the napa dealer and ask for a stant rad cap,and get the 17lbs unit or if they have a higher weight cap even better.Bring the old one to get the right size and you will good to go.The highter the weight pressure of the spring,the higher the boiling piont of the anti freeze becomes.The higher the weight of the cap,the easier the heat will be pulled from the core/fins and reduce your temps,mrmopartech
