(This is about my 15 year olds Duster Project.) I've listened to my engine builder about his ideas. Now I want ideas from you die hard Mopar guys that are living and breathing in your own real life Mopar world and have been where we are now. I would like to give you as many of the particulars about the car as I can, but the simple fact at this point in the build is that we don't know if we will be going with a 904 or an a833. That is absolutely the only thing we don't know about yet. So note that in your response "if you go with the 904, I would do this....If you go with the 4spd, I would do this......" Let's make this sort of a contest! I'll monitor this thread for awhile and when the ideas/posts stop coming I will invite the collective to vote on the best build for the buck.
Here are the particulars on the car.....
1973 Duster originally a 340/auto car. Currently has p/s, but swapping in a manual steering box (will use p/s column and coupler with the manual box if we go with an auto trans (or may consider the Lokar setup with the manual steering column). If we can get a 4sp set up the column will be swapped to the manual column). Power brakes. Battery will be trunk mounted. Frames will be connected. Mini tubs. SS Springs. Fuel cell. Roll cage. We are anticipating getting an 8 3/4 sure grip for the build.
This car will see....let's say 85% street driving and 25% 1/4 mile and maybe some 1/8th mile visits. And yes, I have tried to talk my son into an auto trans simply because it's "better" for the strip enviroment, but you can't argue with a 15 year old when he tells you that the 4spd gains "coolness" points. (He's right! Even though he's 15. 4spds are cool!)
You have a budget of $2000. ALL MACHINE WORK IS FREE OF CHARGE! (Feel free to mention what machine work you feel needs done. Hey, it's free!)
The cam/lifter package you choose will be paid for and is not part of the $2000 budget (X-Mas gift!). In fact, don't even factor a gasket kit or bearings into the $2000.
You have a complete 360 engine to start with (Sorry, I don't know what it came out of and don't have any #'s off of it as it is at the engine builders shop. He picked up the 360 when we picked up the car.) I can get that info if it makes a difference.
Special parameters: Pistons must be forged and the highest compression we can run comfortably on the street (nitrous may be involved). Heads....assume the worst here, but give us your best low budget option (Remember, all machine work is free!). Without a doubt, I'm sure you guys are dry heaving at the idea of using a stock cast head! Go ahead and give us the medial buck option. Better yet, go ahead and give us the high buck option on the heads. Even if it's over the $2000 budget.
So.....Do your best damage for the budget! Let the fantasy building begin!
