Dino
New Member
Hi all,
I dropped in from the Charger forum as I have an A body question and I'm hoping you will be able to help me.
In short I would like to fit an A body condenser in my 69 Charger as my ac lines are from different donors and the discharge line is on the driver's side like an A body.
If you have the 3303 condenser in your car would you mind measuring between the #6 and #8 connections? between the nuts would be perfect. I measure between the two lines on the Charger and have 26 1/2" from the tip of the lines.
Also what is the distance between the bracket holes? I know they won't match up with mine but I should be able to extend those.
Thanks!
Thanks!
