need some knowledge
1mean7Ddart
wilmington Ca
not an A body but what can i do>>>>>>> one of my buddy has a challenger with a 318 to a 383 swap... can he use the two row radiator with the 383 or dose he need to get a different radiator?
Have the original flowed at a Rad shop .... BUT i would bet that you may have to make modifications to keep it cool.... you CANNOT go wrong with recoring original with a 3 core/K core style modine .... NEVER had problems with this sytle reocore .. hands down!
ALSO you can use Original shrould which is a MUST ....
I agree. IMO, it would be best if not just simply perfect to get a new 3 core and factory shorud and viscous fan for this set up. Use distilled water and peak anti frezzeee.
A 2 core from a smaller engine will cool it only so much. My /6 rad cooled my 318 for the most aprt but it did have trouble after a while runing around town. It was like the rad. was just barley under the min. requirement for a mild 318.
It was a new rad and electric fan w/shroud set up. Probably be great for a hopped up /6.
