[WANTED] Need some wiring help?
tekslk
McClure, Pa
67 barracuda my horn relay stuck on and got real hot burnt the wires going from relay to horn, and relay to alternator. Does anybody have these laying around I can buy, or tell me where to get them. I have a new relay on the way.
Post some photos of what you need.
I have a 68 or 69 donor harness and might have the wire/s you are asking about.
67 was unique in the Horn wiring!
The relay was on the right side fender as 68/69 was under the dash on the left kick area.
It is the same relay only mounted under the hood and the trigger wire is in the alternator wiring harness.
  • 67 Barracuda Factory WD REV 1.pdf
That my luck still looking, I can wire and splice if I have to, where can I get the gray two wire t connecter they used on this set up.
