hey, went for a long trip today, and got on the car real hard. at 120+ it has a bad vibration. so bad, it dropped a clip out of the reverse linkage rod at the shifter, so when i pulled off the highway, i drove over those divots on the shoulder, and it fetched on it, and bent the rod. i am needing someone to measure from tip to tip measurement
do not need the length of the actual rod, but if you drew an imaginary line from piont a to point b.
thanks guys
thanks guys
