need source for trim clips '63 Dart GT
MarcD
Active Member
San Francisco
No luck so far on locating a source to replace the 10 plastic push-in trim clips for the roof/quarter panel trim on my'63 Dart GT. Haven't pulled the side moldings off yet, but I suspect there will many more underneath.
I was able to remove the clips by drilling a hole in the center push-in post and threading a sheet metal screw in to extract it...remainder of the clips are not in the best of shape after a half-century of use (nor am I!)
Any leads appreciated!
Wow! That is one comprehensive catalog....thanks for the tip!
I'm also replacing the parking brake handle, and want to thank you for your neat solution with the hardwood block, solid pin and c-clamp. Saved some close-quarters cursing....
