Need Starter Help
68 Coronet RT
68 GTS # 508 in Registry
Upstate New York
Started to install my new TTI exhaust system on my 68 Dart GTS today and ran into a snag, I'm using my stock exhaust manifolds right side fits perfect. Left side is were I ran into a issue with my starter, with the stock starter the pipe will not bolt up to the manifold flange because the starter is to big. Does any one know the number for the smaller mini starters. I heard a starter out of a 86 Dakota is smaller and will work but really not sure.
Yes, the Dakota starter will work. You could also get a mini starter. 65'
Denso 53005984, 91295250, S8357
These are the super shorty 1.4Kw models, the earlier versions were slightly longer (below) and maybe 1.8Kw but the same mini design.
application 1994 Dodge B150 3.6 V6 but spans many years.
