dan69rr
Active Member
View attachment 039 (640x480).jpgSelling 451 Indy Motor different direction;
1971 RB Block
Callie (Hemi 8 bolt flange) 3.75, 4340 material, Mains 2.750 Rod journals 2.375
Main Caps (Aluminum w/ARP studs
Wiseco Pistons flat Top Bore 4.375 w/.990 pin
total Seal Rings w/ file fit
Eagle Rods 6.760 w/.990 pin
Indy Heads 440-1 cnc 345, 68cc heads, 12 to 1 compression
Indy Intake, Indy Valley Cover, Indy Valve Covers
Manley Valves Int. 2.250 w/11-32 stem, Exh. 1.810 w/11-32 stem
Manley Valve dual springs w/10 degree keepers, titanium retainers
Smith Brother Push Rods
Jessel Roller Rockers
Jessel Solid Roller Lifters
Milodon Gear Drive w/adjustable bolt pattern cam gear
Milodon Gear Drive Cover
Milodon 7 qt oil pan w/single hole external oiling
(2) Milodon external oil pumps
(1) Milodon external oil pump dual pick-up feed
Comp-Cam 690 lift 323 duration @50 w/108 center line
Line-bored, Blue printed, Balanced, Deck, Cross deck plate for straightness and squareness.
$11,00.00 asking have over $15.000.00 invested
This motor should make over 800 hp, Have much more performance parts and extras, headers 2'' supercomp, msd dist., 7al msd, alum fuel cell 10 point roll cage, cal trac system, areomotive fuel pump, cheetah shifter,weld end 10'' w/ eagle goodyear drag radios, extra 440 motor on and on pm me, thanks Dan Any feed back would be appriecated...............
Will post pictures of 451 motor need to resize
1971 RB Block
