Need window mounting clip info
paulclark
Early A fanatic
Seattle
On my 66 Dart one of the side windows is missing hardware which attaches the glass to the regulator, and Im having trouble knowing what exactly I'm looking for.
The regulator has an arm which raises and lowers, and the arm has a peg on the end, like a pivot point. Then there is the glass, and a sort of triangular metal bracket which attaches to the window. What I don't have is the small hardware which connects all thes things together. Can anyone point me to the right pieces?
Thanks,
Paul
From what I can see there is some kind of pin and clip that goes through the bracket and through the hole in the window glass. Then there is some other clip (with washer?) that attaches to the regulator pin through the slot in the bracket. If I can find an illustration in the service manual I’ll post it.
Asked the same question a while back , even after finding all the oe part numbers , never found the original parts . So I ended up using these . In the pic for where the pin on the regulator goes into the glass
And the other style push rivets where the bracket for the roller mounts to the glass
Tried all sorts of clips from throttle clips to wiper clips . Never found a similar to oe clip for the pin . So I just used a thin washer and a small Clevis pin
The oe number for the bushing was 2299-809 , and the clip was 2243-390
DOOR GLASS RIVET is the name for the glass to bracket connector, it seems to be the same for A-B-C bodies
Searching for that brought up options including just a single one
WINDOW ARM REGULATOR CLIPS is the name for the bracket to arm post clip.
If you just know the right name to ask for, anything is possible!
