Nere perfect run
572
salina ks
First time out the year. I was a little "gun shy" so I cracked the throttle an hit the brakes in the air to bring it back down. Had a 1.409 60ft with the front tires. Which is pretty lame. Still went 9.21 147.52. Very pleased becouse it was in 3500 ft air an then got rained out.
I could kick myself for "lifting" :banghead:
wish i could be that quick without touching the brakes;)
if you can just keep your fot in it you will run high 8´s
