I had a similar issue. The harnass was half toast and I also had trans years difference like yourself. I just snipped off the end, took note of where the wires went and used some radio shack connectors. They were round in style, actualy designed to fit into one another, a male and female connector. I just used the female ends. Shoved them on and haven't had a problem since then. The fit was a little tight with there use. I suggest some good tape around them to help keep them in order. Not so much retained.
