Neutral Safety Switch Bypass Question...
7T Swinger
1970 Dart, 318, A904. I want to temporarily bypass my neutral safety switch. Where is it located and which wires (color) do you jump? Thanks in advance!
You simply go to the starter relay (next to the battery), find the terminal with the brown wire, take the wire off and and ground the terminal. I have to ask why you want to temporarily bypass it?
Find the brown wire connected to one of the small terminals on the starter relay. Remove the brown wire from the starter relay, and connect a jumper from its terminal on the starter relay to ground.
look for the terminal on the starter relay switch with a G...Ground..
run wire to ground....NSS is not bypassed.
