crooked1/2dozen
Hi:
So I've just got my Chrysler electronic ignition installed....but that's not what this post is about. Took a while to finally get spark, and while messing around with trying different things, the starter started to act up, as in it would only turn over "randomly" on the key , sometimes yes, other times nothing. I bypassed the solenoid with jumpers, starter worked, then hotwired the brown solenoid wire to ground after seeing 12V at the yellow solenoid wire. Seems to work now, so it looks like a bad safety switch. So....after all that, I could have just asked, is the switch servicable, or is it time for a new one, are they available @ NAPA (or Canadian Tire!)? I haven't chased the wire to see where it goes, I imagine on the transmission?
TIA
Dan
TIA
Dan
