neutral switch and reverse lights
Leeroy
Member
Cochrane , Alberta
Hey guys ,
Just getting started on a project after being out of this stuff for a while and need a bit of info.
I'm looking for the neutral switch and the reverse light switch on a 75 - 360 ,4 spd Duster.
The Haynes manual is good but doesn't give me locations on these two switches.
The guy I bought it from had bypassed the neutral switch for some reason , and the lights I'm thinking is a switch issue.
The neutral switch is actually a clutch switch on a manual car. It should be above the clutch pedal inside the car and is contacted by the clutch pedal arm. If this was originally an auto trans car, then it will not have one.... as there was no clutch pedal of course!
The reverse switch should be on the trannie and has 2 prongs; I can't tell you exactly where on that model though.
