isabil22
I am looking at getting a 318 rebuilt to these specs what do you think. thanks Bill
BLOCK IS .030 OVER, CLEANED AND HONED
CASTING DATE 10-5-67
NEW KEITH BLACK PISTONS #KB167-.030
SEALED POWER MOLY RINGS
STOCK CAST CRANK .010/.010
OEM 318 BALANCER
OEM 360 RODS
ROTATING ASSEMBLY BALANCED
NEW SEALED POWER CAM, ROD AND MAIN BEARINGS
NEW SUMMIT .441/.441 LIFT HYD. CAM & LIFTERS #SUM-6901
REDONE 360 HEADS #4027596 WITH HARDENED VALVE SEATS
OEM 360 VALVE SPRINGS WITH 1.88”/1.60” VALVES
STOCK TYPE ROCKER ARM SETUP
NEW BLOCK EXPANSION PLUGS
NEW MELLING HV OIL PUMP AND PICKUP
LATE STYLE FRONT COVER
STEEL TIMING SET
OEM 318 BALANCER
OEM 360 RODS
STEEL TIMING SET
