New balancer won’t press on
Small Block Mopar Engine
  1. DDemon
    DDemon FABO Gold Member FABO Gold Member
    59
    22
    Nov 12, 2014
    Edmonton
    Local Time:
    12:06 AM
    I have a new power bond balancer that I’m having a hard time pressing on. I had a shop take .002 off the inside and now it slides on easily to about halfway (3/4”) and then seems to hit something (?). My balancer installer is bottomed out in the crank, the keyway is lined up, crank is new, I just, put on the front cover, water pump, and oil pan, I have approximately 1.505” from the end of the crank to the oil slinger. This is the balancer with the ridge on the inside but the balancer slides past that. Not sure what I’m missing here. Any suggestions?
  2. Abodybomber
    Abodybomber Breaking street machines , since 1983.....:) Legendary Member
    32,085
    10479
    May 21, 2011
    Arroyo grande ca
    Local Time:
    10:06 PM
    Are you using good lubricant ,on the crank snout / balancer and the threads ,in the crankshaft snout threads ? Second: what " harmonic balancer installer " ,are you using ?
    Third : are you running a aftermarket crank ,and or aftermarket crank bolt ? Let's start ,there...and be patience. Pictures ,would help ,immensely.
    • Like Like x 1
    • 12many
      12many Well-Known Member
      569
      709
      Dec 14, 2016
      South Carolina
      Local Time:
      1:06 AM
      Maybe heat the balancer in the oven, then try installing?
      • Agree Agree x 1
      • famous bob
        famous bob mopar misfit
        11,273
        2798
        Aug 14, 2011
        okla
        Local Time:
        12:06 AM
        I would check the crank snout if the crank is new. Then would junk that balancer and buy a fluid damper in a heartbeat ! Fourth one over the yrs. and no problems ! My last one is from 440 source.
      • krazykuda
        krazykuda FABO Gold Member FABO Gold Member
        46,081
        11169
        Aug 20, 2007
        Orland Park, IL
        Local Time:
        12:06 AM
        Have you measured the crank shaft OD where the balancer goes??? Is it consistent or tapered???
        What about the ID of the balancer??? is it consistent or tapered????
        • Agree Agree x 4
        • Like Like x 3
        • Thanks! Thanks! x 1
        • 12many
          569
          709
          Dec 14, 2016
          South Carolina
          Local Time:
          1:06 AM
          That (checking crank) should have already been done, and then maybe try the heat, grease etc, at least that's what I'd do if money were an issue, but if it just wont happen then "Sling It" !!:eek:
        • DDemon
          59
          22
          Nov 12, 2014
          Edmonton
          Local Time:
          12:06 AM
          Thanks for the replies guys. The balancer was a little tight so I had a machine shop take .002 off the ID. It should have about .001 to .0015 interference fit now. The crank bolt is ARP, I’m using a copper kote lube on the crank, balancer, and threads. Balancer installer is a homemade deal that’s worked well in the past. I can push the balancer on by hand about halfway and then it’s like it butts up against something. Visually there’s nothing there. I’m thinking about pulling the pan and the front cover to see what’s going on.
        • DDemon
          59
          22
          Nov 12, 2014
          Edmonton
          Local Time:
          12:06 AM
          The ID of the balancer was tapered. Not sure how much taper is left after machining.
        • 72Dart6pack
          72Dart6pack Harder Better Faster Stronger.
          2,793
          1825
          Feb 1, 2016
          Roseville Michigan
          Local Time:
          1:06 AM
          :popcorn::popcorn:
        • DDemon
          59
          22
          Nov 12, 2014
          Edmonton
          Local Time:
          12:06 AM
        • DDemon
          59
          22
          Nov 12, 2014
          Edmonton
          Local Time:
          12:06 AM
        • DDemon
          59
          22
          Nov 12, 2014
          Edmonton
          Local Time:
          12:06 AM
          Here’s some pics. The balancer slides on by hand. In the last pic you can see the ridge that was factory machined into the balancer and how far past the ridge it slides over the crank snout. Should the timing cover be loose when installing the balancer?
        • justinp61
          justinp61 Well-Known Member
          1,163
          461
          May 15, 2009
          Local Time:
          12:06 AM
          IMO if the damper slips on by hand it's junk already. Here is what ATI recommends.
          http://www.atiracing.com/instructions/Super-Damper.pdf
          • Agree Agree x 4
          • 72Dart6pack
            2,793
            1825
            Feb 1, 2016
            Roseville Michigan
            Local Time:
            1:06 AM
            Yeah thats a paperweight or doorstop now. Nothing more.
          • famous bob
            11,273
            2798
            Aug 14, 2011
            okla
            Local Time:
            12:06 AM
            I`m not familiar w/ that timing cover, are u sure that bolt sticking out isn`t hitting the dampener ?
            • Like Like x 1
            • DDemon
              59
              22
              Nov 12, 2014
              Edmonton
              Local Time:
              12:06 AM
              It isn’t hitting the bolt sticking out, it’s pretty far away. I’m thinking I’ll pull the oil pan, water pump and front cover and getting to the bottom of this. The front cover is a standard late 70s Chrysler piece.
            • Red63440
              Red63440 Olddawg
              211
              111
              Dec 13, 2011
              Batavia, NY
              Local Time:
              1:06 AM
              Try removing the wood ruff key and seeing if it will slide on.
              • Agree Agree x 1
              • yellow rose
                yellow rose Doctor of Thinkology.
                15,415
                12025
                Jun 19, 2015
                Living on the razors edge
                Local Time:
                10:06 PM
                Yup, if that slides on its 100% junk and if you use it, it will 100% make more junk.
                Junk is junk at any price.
              • DDemon
                59
                22
                Nov 12, 2014
                Edmonton
                Local Time:
                12:06 AM
                I’ll try removing the key and report back. I’ll also see if I have a stock balancer kicking around and see if that fits.
                • Like Like x 1
                • famous bob
                  11,273
                  2798
                  Aug 14, 2011
                  okla
                  Local Time:
                  12:06 AM
                  curious now, what engine is this? I musta missed it .
                • MrJLR
                  MrJLR Built, not bought FABO Gold Member
                  4,154
                  2816
                  May 14, 2015
                  Chino, California
                  Local Time:
                  10:06 PM
                  Yer gonna need a new balancer bud....should be a press fit.
                  Sucks to hear I know. ...but this is how we learn.
                  Jeff
                  • Agree Agree x 2
                  • DDemon
                    59
                    22
                    Nov 12, 2014
                    Edmonton
                    Local Time:
                    12:06 AM
                    The engine is a 4” stroke 360.
                  • DDemon
                    59
                    22
                    Nov 12, 2014
                    Edmonton
                    Local Time:
                    12:06 AM
                    Even before I had .002 taken out of the balancer it would still slide on pretty far. Seems like a tapered fit.
                  • jimjimjimmy
                    jimjimjimmy lobsterman FABO Gold Member
                    4,077
                    858
                    Nov 2, 2010
                    p. e. i.
                    Local Time:
                    2:06 AM
                    did you read and do what was said in post 5 that will tell you everything .
                  • justinp61
                    1,163
                    461
                    May 15, 2009
                    Local Time:
                    12:06 AM
                    I always use the guidelines in the link I posted for damper fit. I mic the crank snout to make sure not tapered or out of round. Once I'm satisfied I'll put the mic on the crank and lock it down. Then I take my mic to the machine shop and they use it to set up their machine. My machine shop uses a Sunnen rod hone to hone dampers. I've never had an issue doing it this way.
